[Qgis-developer] Temporal data (was QGIS GRASS Plugin Upgrade Crowdfunding)
Radim Blazek
radim.blazek at gmail.com
Mon Mar 30 00:47:45 PDT 2015
Hi again.
On Tue, Mar 24, 2015 at 10:04 AM, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
>> Are there functions in time series implementation which need to be
>> called directly from the plugin or everything may be done just calling
>> t.rast.* modules?
> Most of the temporal functionality is available through the temporal
> modules. However some important algorithms (temporal re-sampling) are
> available only in the Python framework. This is needed for time series
> animation creation. Using the framework directly will speed things up,
> because the module calls, the parsing and interpretation of the module
> outputs can be avoided.
I am getting convinced that the temporal data visualization support
should be added to QGIS core. A single time navigation toolbar
(from/to, start/stop, previous/next) and temporal support in data
providers (QgsVectorDataProvider::getFeatures,
QgsRasterDataProvider::block). That would allow simultaneous animation
of temporal data from various sources in different formats (time frame
defined by band, layer or attribute).
There are already 3 plugins for temporal data management [1][2][3],
writing another one seems misconception and wasting of resources.
[1] https://plugins.qgis.org/plugins/timemanager/
[2] https://plugins.qgis.org/plugins/multiview/
[3] https://plugins.qgis.org/plugins/temporalprofiletool/
Radim
