[Qgis-developer] Open hub tickets target versions
Jürgen E. Fischer jef at norbit.de
Fri May 8 10:54:33 PDT 2015
Hi Sandro,
On Fri, 08. May 2015 at 19:48:28 +0200, Sandro Santilli wrote:
> So are you suggesting that only the "assigner" should set target ?
The assignee - yes.  as there otherwise is a good chance the target won't be
met and we just end up moving it again...
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150508/26f53cb1/attachment.pgp>
