[Qgis-developer] Problem with the MySQL/GDAL implementation in QGIS
Matthias Kuhn matthias at opengis.ch
Mon May 11 00:41:39 PDT 2015
On 05/11/2015 09:29 AM, Pavol Hnila wrote:
> The principal problem pointed out by Even however remains - the
> repeated opening and closing of the OGR datasource for every record in
> the table. I will try to figure out which nightly build between 1.8
> and 2.0 release caused this change in behaviour. Since I cannot figure
> it out in the code and need to try manually, this can take some time.
> Unless someone else on the list can figure it out from the master code ...
It was most likely that one:
0b9d1dc49b3277a842d0a18a2f1ba99782965999
Matthias
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150511/014870ed/attachment.pgp>
