[Qgis-developer] Compliation issues of sources using "make" on Linux Ubuntu
Florin-Daniel Cioloboc cioloboc.florin at gmail.com
Mon May 11 03:06:31 PDT 2015
Thanks for the reply Alessandro,
Already done that. It still doesn't work yet, however I got the idea to
source it: source scripts/run-env-linux.sh /usr/bin/qgis-2.2/ and it worked
up, at least that command.
Unfortunately, when running make test command it get the same permission
error so at the moment I'm trying to set it using chmod but it doesn't seem
to be working.
On Mon, May 11, 2015 at 11:45 AM, Alessandro Pasotti <apasotti at gmail.com>
wrote:
> 2015-05-11 10:44 GMT+02:00 Florin-Daniel Cioloboc <
> cioloboc.florin at gmail.com>:
>> Hello everyone,
>> I am getting a rather strange message after using the make command, which
>> is preventing me from compiling my sources for a plugin. As a result, the
>> plugin doesn't show up in QGIS.
>> Message:
>>> Compiled translation files to .qm files.
>>> make: execvp: scripts/compile-strings.sh: Permission denied
>>> make: *** [transcompile] Error 127
>> Had an earlier issue but it was partly solved by installing PyQT4. I
>> don't really understand what's wrong.
>> I typed in prompt: *make test* and got:
>>> pyrcc4 -o resources_rc.py  resources.qrc
>>> make: pyrcc4: Command not found
>>> make: *** [resources_rc.py] Error 127
>>> I could use really use some help.
> You have to install pyrcc4, if you're on Linux Ubuntu  or Debian it's in
> the pyqt4-dev-tools package.
> Alessandro Pasotti
> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150511/4b4ea74a/attachment.html>
