[Qgis-developer] Compliation issues of sources using "make" on Linux Ubuntu
Florin-Daniel Cioloboc cioloboc.florin at gmail.com
Mon May 11 03:16:05 PDT 2015
Apparently, neither chmod +x scripts/compile-strings.sh nor chmod 001
scripts/compile-strings.sh work.
Whenever I use make test:
> Compiled translation files to .qm files.
> make: execvp: scripts/compile-strings.sh: Permission denied
> make: *** [transcompile] Error 127
Does anyone know why?
On Mon, May 11, 2015 at 12:06 PM, Florin-Daniel Cioloboc <
cioloboc.florin at gmail.com> wrote:
> Thanks for the reply Alessandro,
> Already done that. It still doesn't work yet, however I got the idea to
> source it: source scripts/run-env-linux.sh /usr/bin/qgis-2.2/ and it worked
> up, at least that command.
> Unfortunately, when running make test command it get the same permission
> error so at the moment I'm trying to set it using chmod but it doesn't seem
> to be working.
> On Mon, May 11, 2015 at 11:45 AM, Alessandro Pasotti <apasotti at gmail.com>
> wrote:
>> 2015-05-11 10:44 GMT+02:00 Florin-Daniel Cioloboc <
>> cioloboc.florin at gmail.com>:
>>> Hello everyone,
>>> I am getting a rather strange message after using the make command,
>>> which is preventing me from compiling my sources for a plugin. As a result,
>>> the plugin doesn't show up in QGIS.
>>> Message:
>>> Had an earlier issue but it was partly solved by installing PyQT4. I
>>> don't really understand what's wrong.
>>> I typed in prompt: *make test* and got:
>>>> pyrcc4 -o resources_rc.py  resources.qrc
>>>> make: pyrcc4: Command not found
>>>> make: *** [resources_rc.py] Error 127
>>>> I could use really use some help.
>> You have to install pyrcc4, if you're on Linux Ubuntu  or Debian it's in
>> the pyqt4-dev-tools package.
>> Alessandro Pasotti
>> w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150511/9b97103f/attachment-0001.html>
