[Qgis-developer] Compliation issues of sources using "make" on Linux Ubuntu
Hugo Mercier hugo.mercier at oslandia.com
Mon May 11 05:13:35 PDT 2015
Make sure you are on a file system that support unix file execution
permission (no ntfs) and that it is mounted correctly.
Make also sure that the user running make is the same as the owner of
all files.
On 11/05/2015 12:16, Florin-Daniel Cioloboc wrote:
> Apparently, neither chmod +x scripts/compile-strings.sh nor chmod 001
> scripts/compile-strings.sh work.
> Whenever I use make test:
>     Compiled translation files to .qm files.
>     make: execvp: scripts/compile-strings.sh: Permission denied
>     make: *** [transcompile] Error 127
> Does anyone know why?
> On Mon, May 11, 2015 at 12:06 PM, Florin-Daniel Cioloboc
> <cioloboc.florin at gmail.com <mailto:cioloboc.florin at gmail.com>> wrote:
>     Thanks for the reply Alessandro,
>     Already done that. It still doesn't work yet, however I got the idea
>     to source it: source scripts/run-env-linux.sh /usr/bin/qgis-2.2/ and
>     it worked up, at least that command.
>     Unfortunately, when running make test command it get the same
>     permission error so at the moment I'm trying to set it using chmod
>     but it doesn't seem to be working.
>     On Mon, May 11, 2015 at 11:45 AM, Alessandro Pasotti
>     <apasotti at gmail.com <mailto:apasotti at gmail.com>> wrote:
>         2015-05-11 10:44 GMT+02:00 Florin-Daniel Cioloboc
>         <cioloboc.florin at gmail.com <mailto:cioloboc.florin at gmail.com>>:
>             Hello everyone,
>             I am getting a rather strange message after using the make
>             command, which is preventing me from compiling my sources
>             for a plugin. As a result, the plugin doesn't show up in QGIS.
>             Message:
>             Had an earlier issue but it was partly solved by installing
>             PyQT4. I don't really understand what's wrong.
>                 I typed in prompt: /make test/ and got:
>                 |pyrcc4 -o resources_rc.py  resources.qrc
>                 make: pyrcc4: Command not found
>                 make: *** [resources_rc.py] Error 127|
>             I could use really use some help.
>         You have to install pyrcc4, if you're on Linux Ubuntu  or Debian
>         it's in the pyqt4-dev-tools package.
>         Alessandro Pasotti
>         w3:   www.itopen.it <http://www.itopen.it>
> Qgis-developer mailing list
