[Qgis-developer] QGIS to ArcGIS Map Package
Andreas Neumann a.neumann at carto.net
Sat May 16 04:19:50 PDT 2015
Hi Zoltan,
You are right. The two formats are incompatible - and there is no
documentation of ArcGIS file formats available.
If you know documentation about the ArcGIS Map package format (is this
different from mxd?) there would be hope.
Andreas
On 16.05.2015 13:16, Zoltan wrote:
> Hi Again,
> I'm guessing the resounding silence means a resounding "NO!" ??
> Regards to all,
> Zoltan
> On 15/05/2015 16:08, Zoltan Szecsei wrote:
>> Hi,
>> Once I have created a map in the QGIS print composer, is there a way
>> to export it to "ArcGIS Map Package" format?
>> Thanks & regards,
>> Zoltan
> Qgis-developer mailing list
