[Qgis-developer] QGIS to ArcGIS Map Package
Zoltan
zoltans at geograph.co.za
Sat May 16 04:25:54 PDT 2015
Hi Andreas,
Drat!
Although I did think as much.
As a non-ESRI user that kind of makes life more difficult creating
deliverables.
Good old "monopoly at work" situation.
Would be kind of nice if this was viewed as anti-competitive :-)
Thanks for your 2c.
Regards,
Zoltan
On 16/05/2015 13:19, Andreas Neumann wrote:
> Hi Zoltan,
> You are right. The two formats are incompatible - and there is no
> documentation of ArcGIS file formats available.
> If you know documentation about the ArcGIS Map package format (is this
> different from mxd?) there would be hope.
> Andreas
> On 16.05.2015 13:16, Zoltan wrote:
>> Hi Again,
>> I'm guessing the resounding silence means a resounding "NO!" ??
>> Regards to all,
>> Zoltan
>> On 15/05/2015 16:08, Zoltan Szecsei wrote:
>>> Hi,
>>> Once I have created a map in the QGIS print composer, is there a way
>>> to export it to "ArcGIS Map Package" format?
>>> Thanks & regards,
>>> Zoltan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
