[Qgis-developer] Value map behaviour for data entry and display
Nathan Woodrow
madmanwoo at gmail.com
Mon May 18 00:03:56 PDT 2015
I agree. The current behavior is the correct one. If you need to see the
values just add them to your description (maybe we can have that as a auto
option)
- Nathan
On Mon, 18 May 2015 at 17:01 Jürgen E. <jef at norbit.de> wrote:
> Hi Paolo,
> On Sun, 17. May 2015 at 22:27:03 +0200, Paolo Cavallini wrote:
> > to speed up data entry, especially in case of many similar names.
> Isn't that an edge case? When using value map you usually don't have to
> care
> about the key values at all. And for edge cases you could also include
> the key values in the description and have both.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150518/a8eb9a41/attachment.html>
