[Qgis-developer] Value map behaviour for data entry and display
Bob and Deb
bobdebm at gmail.com
Mon May 18 07:55:15 PDT 2015
Having an option would be great! In one of our forms, we have a soil
classification field. The students that are entering borehole data relies
on the description while the Geologist rather look at the code. An option
to show both would be code and descriptions would be great!
On May 18, 2015 12:04 AM, "Nathan Woodrow" <madmanwoo at gmail.com> wrote:
> I agree. The current behavior is the correct one. If you need to see the
> values just add them to your description (maybe we can have that as a auto
> option)
> - Nathan
> On Mon, 18 May 2015 at 17:01 Jürgen E. <jef at norbit.de> wrote:
>> Hi Paolo,
>> On Sun, 17. May 2015 at 22:27:03 +0200, Paolo Cavallini wrote:
>> > to speed up data entry, especially in case of many similar names.
>> Isn't that an edge case? When using value map you usually don't have to
>> care
>> about the key values at all. And for edge cases you could also include
>> the key values in the description and have both.
>> Jürgen
>> Jürgen E. Fischer norBIT GmbH Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>> +49-4931-918175-50
>> Software Engineer D-26506 Norden
>> http://www.norbit.de
>> QGIS release manager (PSC) Germany IRC: jef on
>> FreeNode
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150518/f92c2efa/attachment.html>
