[Qgis-developer] Crash in new GRASS plugin?
Paolo Cavallini cavallini at faunalia.it
Thu May 21 01:27:43 PDT 2015
Hi Radim,
Il 21/05/2015 09:13, Radim Blazek ha scritto:
> AFAICT, it can only happen if you have GISRC set, but the file does
> not exist or it is corrupted. Try to unset GISRC envar and it should
> run.
I think this is due to Processing, that sets temp grass variables.
> It should not crash of course, the exception is now caught (8c8a123).
thanks
> BTW: "qgsgrass.cpp: 483: (error_routine), [4ms]  error_routine (fatal
> = 1): G_getenv(): Variable GISDBASE not set" says that the build is
> rather old, the last qgsgrass.cpp commit with that row was 7091d3, May
> 18. Please use a fresh build if possible.
sorry, I'm using packages now. will do more tests with a fresh version,
when you'll ask for it.
all the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
