[Qgis-developer] issue with QGIS via citrix
Wisse Beets
W.Beets at wareco.nl
Fri May 22 04:18:38 PDT 2015
Dear QGIS users,
I am experiencing a problem using Qgis 2.6.1 (and several prior versions) via thin client systems.
The machines are running Windows Server 2008 and Citrix Receiver. The problem is that edits to vector shapefiles are not always saved, while the 'save edits' button is pressed and the changes are visible in the attribute tables. After reopening the vector file later, it appears that sometimes (randomly) the changes are lost/were not saved to the file. We save our files to a network drive. This works fine with other software and on our desktop systems. This problem only occurs on our thin client systems.
Did anyone experience this problem before and/or knows a possible solution or workaround?
Kind Regards,
Wisse Beets,
Consultant watermanagement
Wareco Ingenieurs
Amstelveen
