[Qgis-developer] Compile QGIS master with support for GRASS
Richard Duivenvoorde rdmailings at duif.net
Mon May 25 07:17:20 PDT 2015
On 25-05-15 10:15, Radim Blazek wrote:
>> > I launch QGIS without installing it, ie from inside the bin directory.
>> > It runs fine.  However, I can't see anywhere in QGIS' interface any
>> > reference to GRASS. Plus, many of the icons do not appear at all (ie
>> > icons of the advanced digitizing bar).
> You need to add path to GRASS libs to LD_LIBRARY_PATH before you run
> QGIS, for example
Ah! I had the same problem, even asked around during the hackfest...
nobody could tell me this :-)
Thanks Radim
Regards,
