[Qgis-developer] Compile QGIS master with support for GRASS
Radim Blazek
radim.blazek at gmail.com
Mon May 25 07:31:59 PDT 2015
On Mon, May 25, 2015 at 4:17 PM, Richard Duivenvoorde
<rdmailings at duif.net> wrote:
> On 25-05-15 10:15, Radim Blazek wrote:
>>> > I launch QGIS without installing it, ie from inside the bin directory.
>>> > It runs fine. However, I can't see anywhere in QGIS' interface any
>>> > reference to GRASS. Plus, many of the icons do not appear at all (ie
>>> > icons of the advanced digitizing bar).
>> You need to add path to GRASS libs to LD_LIBRARY_PATH before you run
>> QGIS, for example
> Ah! I had the same problem, even asked around during the hackfest...
> nobody could tell me this :-)
Sorry, I wanted to announce everything in a single message.
Radim
> Thanks Radim
> Regards,
> Qgis-developer mailing list
