[Qgis-developer] Compile QGIS master with support for GRASS
Richard Duivenvoorde
rdmailings at duif.net
Mon May 25 07:42:37 PDT 2015
On 25-05-15 16:31, Radim Blazek wrote:
> On Mon, May 25, 2015 at 4:17 PM, Richard Duivenvoorde
> <rdmailings at duif.net> wrote:
>> On 25-05-15 10:15, Radim Blazek wrote:
>>>>> I launch QGIS without installing it, ie from inside the bin directory.
>>>>> It runs fine. However, I can't see anywhere in QGIS' interface any
>>>>> reference to GRASS. Plus, many of the icons do not appear at all (ie
>>>>> icons of the advanced digitizing bar).
>>> You need to add path to GRASS libs to LD_LIBRARY_PATH before you run
>>> QGIS, for example
>> Ah! I had the same problem, even asked around during the hackfest...
>> nobody could tell me this :-)
> Sorry, I wanted to announce everything in a single message.
No worries, stick to your plan. I was just happy that the grass plugin
revealed itself now.
Eager to hear about all the hardwork you have been doing in your message
after the freeze and sorry for the spoiler ;-)
Regards,
Richard
