[Qgis-developer] Compile QGIS master with support for GRASS
Nikos Alexandris nik at nikosalexandris.net
Mon May 25 10:13:22 PDT 2015
* Richard Duivenvoorde <rdmailings at duif.net> [2015-05-25 16:42:37 +0200]:
> On 25-05-15 16:31, Radim Blazek wrote:
> > On Mon, May 25, 2015 at 4:17 PM, Richard Duivenvoorde
> > <rdmailings at duif.net> wrote:
> >> On 25-05-15 10:15, Radim Blazek wrote:
> >>>>> I launch QGIS without installing it, ie from inside the bin directory.
> >>>>> It runs fine.  However, I can't see anywhere in QGIS' interface any
> >>>>> reference to GRASS. Plus, many of the icons do not appear at all (ie
> >>>>> icons of the advanced digitizing bar).
> >>> You need to add path to GRASS libs to LD_LIBRARY_PATH before you run
> >>> QGIS, for example
> >> Ah! I had the same problem, even asked around during the hackfest...
> >> nobody could tell me this :-)
> > Sorry, I wanted to announce everything in a single message.
> No worries, stick to your plan. I was just happy that the grass plugin
> revealed itself now.
> Eager to hear about all the hardwork you have been doing in your message
> after the freeze and sorry for the spoiler ;-)
Oops, I really was not aware of the upcoming news, though I do follow
the development of the plugin.
Apologies, Nikos
