[Qgis-developer] QGIS master on Windows crashes on exit
Matthias Kuhn
matthias at opengis.ch
Tue May 26 01:39:36 PDT 2015
On 05/26/2015 10:29 AM, Blumentrath, Stefan wrote:
> Hi,
> Confirmed also for code revision: 2ff6f72 on Win7 32bit...
> Cheers,
> Stefan
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
> Sent: 26. mai 2015 10:22
> To: qgis-developer
> Subject: [Qgis-developer] QGIS master on Windows crashes on exit
> Hi,
> It seems like a recent master version
> (https://github.com/qgis/QGIS/commit/b91e43a) crashes on exit. I installed through OSGEO4W.
> Can others confirm?
> Thanks,
> Andreas
> Qgis-developer mailing list
Do you know, was May 22 build still ok? And May 24 build broken?
If you are able to compile, can you test if reverting the following two
commits fixes it:
10239a0
dbdfe40
Matthias
