[Qgis-developer] QGIS master on Windows crashes on exit
Andreas Neumann
a.neumann at carto.net
Tue May 26 02:56:51 PDT 2015
Hi Matthias,
Unfortunately I don't have a build environment on Windows.
My Linux system with the newest master build does not seem to be
affected by this crash on exit.
I'll write these two commits in the bug report so the dev dealing with
this could investigate whether these two patches are the cause.
See http://hub.qgis.org/issues/12822
Thanks,
Andreas
> Do you know, was May 22 build still ok? And May 24 build broken?
> If you are able to compile, can you test if reverting the following two
> commits fixes it:
> 10239a0
> dbdfe40
> Matthias
