[Qgis-developer] Compile QGIS master with support for GRASS
Nikos Alexandris
nik at nikosalexandris.net
Tue May 26 05:38:55 PDT 2015
Nikos:
> >> QGIS is installed in /osgeo/QGIS/ and
> >> /osgeo/QGIS/grass/config/default.qgc exists?
> >> The path is constructed as QgsApplication::pkgDataPath() +
> >> "/grass/config/default.qgc".
> >> For now, I think that you have to install QGIS to get it working (or
> >> do some dirty trick like symlinks from /osgeo/QGIS/grass/).
> > Honestly, I am afraid to install. I want to avoid hunting
> > files here and there when it comes to remove it.
Radim:
> Why here and there? With CMAKE_INSTALL_PREFIX you install where you want.
Because of past experiences with make uninstall not really doing what
it was supposed to do.
It works now though :-). Both installing and uninstalling.
> > I'll try to symlink.
Both, installing and symlinking work as far as doing away with the
reported error message and the GRASS(64) plugin is available (toolbar and
toolbox). Yet, most icons are invisible, the descriptions in the toolbox are
ok (I think, I didn't check all).
Re-exporting the LD_LIBRARY_PATH for G7, however, does not do any magic.
But, I can wait for the upcoming announcments.
Thanks a million, Nikos
