[Qgis-developer] Compile QGIS master with support for GRASS
Radim Blazek radim.blazek at gmail.com
Tue May 26 03:49:27 PDT 2015
On Tue, May 26, 2015 at 9:38 AM, Nikos Alexandris
<nik at nikosalexandris.net> wrote:
> Radim:
>> QGIS is installed in /osgeo/QGIS/ and
>> /osgeo/QGIS/grass/config/default.qgc exists?
>> The path is constructed as QgsApplication::pkgDataPath() +
>> "/grass/config/default.qgc".
>> For now, I think that you have to install QGIS to get it working (or
>> do some dirty trick like symlinks from /osgeo/QGIS/grass/).
> Honestly, I am afraid to install.  I want to avoid hunting
> files here and there when it comes to remove it.
Why here and there? With CMAKE_INSTALL_PREFIX you install where you want.
Radim
> I'll try to symlink.  Thank you, Nikos
> ps- kind of a "to self" note: I should write an ebuild for this
> (Funtoo-Linux user here), but I cannot afford to do so right now.
