[Qgis-developer] Compile QGIS master with support for GRASS
Nikos Alexandris
nik at nikosalexandris.net
Tue May 26 00:38:06 PDT 2015
Nikos:
> > I can see the plugin for 64 now. However, trying to open a (new) Mapset,
> > returns "The config file /osgeo/QGIS/grass/config/default.qgc) not
> > found.". And the GRASS toolbar icons (as well as for other toolbars)
> > are (partially or completely) invisible.
Radim:
> QGIS is installed in /osgeo/QGIS/ and
> /osgeo/QGIS/grass/config/default.qgc exists?
> The path is constructed as QgsApplication::pkgDataPath() +
> "/grass/config/default.qgc".
> For now, I think that you have to install QGIS to get it working (or
> do some dirty trick like symlinks from /osgeo/QGIS/grass/).
Honestly, I am afraid to install. I want to avoid hunting
files here and there when it comes to remove it.
I'll try to symlink. Thank you, Nikos
ps- kind of a "to self" note: I should write an ebuild for this
(Funtoo-Linux user here), but I cannot afford to do so right now.
