[Qgis-developer] Dev map broken in About?
Paolo Cavallini cavallini at faunalia.it
Wed May 27 05:05:59 PDT 2015
Il 27/05/2015 13:18, Andreas Neumann ha scritto:
> At my system, the background map appears only after you click on a
> placemark. After clicking on any placemark, the background map appears
> immediately and navigation is working fine.
> Maybe some sort of problem that Webkit does not correctly trigger parts
> of the script?
Thanks Andreas, same thing happens here, so probably you spotted the issue.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
