[Qgis-developer] QGIS as WPS server?
Larry Shaffer larrys at dakotacarto.com
Thu May 28 20:17:58 PDT 2015
I also am involved with some work that can benefit from WPS integration of
Processing, and found René-Luc's new plugin while searching today.
What would help further in my situation is to be able to export the
Processing model into a format that can be loaded as a backend process in
another WPS setup, e.g. GeoServer with WPS, but configured via QGIS.
René-Luc, any thoughts on that?
Is there a standardized definition for WPS that describing input/outputs
that a Processing model can be exported into (assuming all dependencies
would be the same on the remote server executing the process)? I looked in
the spec and noticed the WPS Native Process Model [0]. Any experience with
that?
[0] http://docs.opengeospatial.org/is/14-065/14-065.html#18
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Mon, May 18, 2015 at 3:05 AM, René-Luc Dhont <rldhont at gmail.com> wrote:
> Hi Paolo,
> Here is a first implementation :
> https://github.com/rldhont/PyWPS-QGIS-Processing
> And I have to port it to QGIS-Server-Plugin.
> All feedbacks are welcome.
> Regards
> Le 18/05/2015 11:02, Paolo Cavallini a écrit :
>> Hi all.
>> I have some interest in having a full implementation of QGIS as WPS
>> server. Is there anyone interested as well? Can we have a chat at the
>> HF, possibly joined by others on IRC?
>> Thanks.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150528/4582cafd/attachment.html>
