[Qgis-developer] QGIS as WPS server?
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri May 29 00:28:40 PDT 2015
Hi Larry,
Maybe the WPS-GRASS-bridge:
https://code.google.com/p/wps-grass-bridge/wiki/PyWPS_Integration
could give some inspiration!?
Cheers
Stefan
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Larry Shaffer
Sent: 29. mai 2015 05:18
To: René-Luc Dhont
Cc: QGIS Developer List
Subject: Re: [Qgis-developer] QGIS as WPS server?
I also am involved with some work that can benefit from WPS integration of Processing, and found René-Luc's new plugin while searching today.
What would help further in my situation is to be able to export the Processing model into a format that can be loaded as a backend process in another WPS setup, e.g. GeoServer with WPS, but configured via QGIS. René-Luc, any thoughts on that?
Is there a standardized definition for WPS that describing input/outputs that a Processing model can be exported into (assuming all dependencies would be the same on the remote server executing the process)? I looked in the spec and noticed the WPS Native Process Model [0]. Any experience with that?
[0] http://docs.opengeospatial.org/is/14-065/14-065.html#18
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Mon, May 18, 2015 at 3:05 AM, René-Luc Dhont <rldhont at gmail.com<mailto:rldhont at gmail.com>> wrote:
Hi Paolo,
Here is a first implementation :
https://github.com/rldhont/PyWPS-QGIS-Processing
And I have to port it to QGIS-Server-Plugin.
All feedbacks are welcome.
Regards
Le 18/05/2015 11:02, Paolo Cavallini a écrit :
Hi all.
I have some interest in having a full implementation of QGIS as WPS
server. Is there anyone interested as well? Can we have a chat at the
HF, possibly joined by others on IRC?
Thanks.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150529/54a13df3/attachment-0001.html>
