[Qgis-developer] There is a way to eliminate the "Recent Projects" startup screen ?
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Nov 12 04:07:44 PST 2015
As mentioned before I think the new opening screen with recent projects is
a great feature. However, an improvement would be to automatically remove
the projects that cannot be found (greyed out ones) as suggested by Stefan.
Or the option to manually remove them from the list?
Moving them to the bottom is another option, but what would be the reason
to keep them to start with? I could see a point if one can click on it and
search for the new location, but as it is now, it only shows in the list.
Paulo
On Thu, Nov 12, 2015 at 11:57 AM, Blumentrath, Stefan <
Stefan.Blumentrath at nina.no> wrote:
> Hi,
> R for example does save the “workspace” for a session on request, but I am
> not sure if this is so relevant for QGIS at all. Actually, IMHO much better
> to start an empty project by default than a (probably heavy) recent project
> one does not want to continue with.
> Something that might improve the situation in a simple way (though I have
> no problems with the current situation) could be to mark (e.g. grey out)
> projects that were moved (cannot be found at the specified location) or
> those could be put to the end of the list or something like that…
> Cheers
> Stefan
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151112/71e831d4/attachment.html>
