[Qgis-developer] There is a way to eliminate the "Recent Projects" startup screen ?
DelazJ delazj at gmail.com
Thu Nov 12 04:13:16 PST 2015
Yes it would be nice to be able to remove them when no more useful or just
to hide them from people (as some stated) but don't make it automatic.
Sometimes, you may open QGIS without having access to the network where
projects are available. Having them cleared just because you didn't check
access before would not be convenient. Rather grey them (and add a cross on
each project for removal).
2015-11-12 13:07 GMT+01:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
> As mentioned before I think the new opening screen with recent projects is
> a great feature. However, an improvement would be to automatically remove
> the projects that cannot be found (greyed out ones) as suggested by Stefan.
> Or the option to manually remove them from the list?
> Moving them to the bottom is another option, but what would be the reason
> to keep them to start with? I could see a point if one can click on it and
> search for the new location, but as it is now, it only shows in the list.
> Paulo
> On Thu, Nov 12, 2015 at 11:57 AM, Blumentrath, Stefan <
> Stefan.Blumentrath at nina.no> wrote:
>> Hi,
>> R for example does save the “workspace” for a session on request, but I
>> am not sure if this is so relevant for QGIS at all. Actually, IMHO much
>> better to start an empty project by default than a (probably heavy) recent
>> project one does not want to continue with.
>> Something that might improve the situation in a simple way (though I have
>> no problems with the current situation) could be to mark (e.g. grey out)
>> projects that were moved (cannot be found at the specified location) or
>> those could be put to the end of the list or something like that…
>> Cheers
>> Stefan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151112/87d97423/attachment-0001.html>
