[Qgis-developer] There is a way to eliminate the "Recent Projects" startup screen ?
    Paulo van Breugel
    p.vanbreugel at gmail.com
    Thu Nov 12 04:16:14 PST 2015
Yes, I hadn't thought about projects on network, good point. Adding a cross
to easily remove them is a good idea.
On Thu, Nov 12, 2015 at 1:13 PM, DelazJ <delazj at gmail.com> wrote:
> Hi,
> Yes it would be nice to be able to remove them when no more useful or just
> to hide them from people (as some stated) but don't make it automatic.
> Sometimes, you may open QGIS without having access to the network where
> projects are available. Having them cleared just because you didn't check
> access before would not be convenient. Rather grey them (and add a cross on
> each project for removal).
> 2015-11-12 13:07 GMT+01:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
>> As mentioned before I think the new opening screen with recent projects
>> is a great feature. However, an improvement would be to automatically
>> remove the projects that cannot be found (greyed out ones) as suggested by
>> Stefan. Or the option to manually remove them from the list?
>> Moving them to the bottom is another option, but what would be the reason
>> to keep them to start with? I could see a point if one can click on it and
>> search for the new location, but as it is now, it only shows in the list.
>> Paulo
>> On Thu, Nov 12, 2015 at 11:57 AM, Blumentrath, Stefan <
>> Stefan.Blumentrath at nina.no> wrote:
>>> Hi,
>>> R for example does save the “workspace” for a session on request, but I
>>> am not sure if this is so relevant for QGIS at all. Actually, IMHO much
>>> better to start an empty project by default than a (probably heavy) recent
>>> project one does not want to continue with.
>>> Something that might improve the situation in a simple way (though I
>>> have no problems with the current situation) could be to mark (e.g. grey
>>> out) projects that were moved (cannot be found at the specified location)
>>> or those could be put to the end of the list or something like that…
>>> Cheers
>>> Stefan
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151112/ed8b48a3/attachment.html>
