[Qgis-developer] There is a way to eliminate the "Recent Projects" startup screen ?
Yves Jacolin yjacolin at free.fr
Thu Nov 12 04:51:32 PST 2015
Hello,
I agree that manual removing is a better choice.
What if you moved the project file? You can choose to remove it from your
"recent projects" or maybe change the path when double clicking on it, a
windows dialog ask you to define the correct path, in the same way we can do it
for layer.
Y.
On Thursday, November 12, 2015 13:16:14 Paulo van Breugel wrote:
> Yes, I hadn't thought about projects on network, good point. Adding a cross
> to easily remove them is a good idea.
> On Thu, Nov 12, 2015 at 1:13 PM, DelazJ <delazj at gmail.com> wrote:
> > Hi,
> > Yes it would be nice to be able to remove them when no more useful or just
> > to hide them from people (as some stated) but don't make it automatic.
> > Sometimes, you may open QGIS without having access to the network where
> > projects are available. Having them cleared just because you didn't check
> > access before would not be convenient. Rather grey them (and add a cross
> > on
> > each project for removal).
> > 2015-11-12 13:07 GMT+01:00 Paulo van Breugel <p.vanbreugel at gmail.com>:
> >> As mentioned before I think the new opening screen with recent projects
> >> is a great feature. However, an improvement would be to automatically
> >> remove the projects that cannot be found (greyed out ones) as suggested
> >> by
> >> Stefan. Or the option to manually remove them from the list?
> >> Moving them to the bottom is another option, but what would be the reason
> >> to keep them to start with? I could see a point if one can click on it
> >> and
> >> search for the new location, but as it is now, it only shows in the list.
> >> Paulo
> >> On Thu, Nov 12, 2015 at 11:57 AM, Blumentrath, Stefan <
> >> Stefan.Blumentrath at nina.no> wrote:
> >>> Hi,
> >>> R for example does save the “workspace” for a session on request, but I
> >>> am not sure if this is so relevant for QGIS at all. Actually, IMHO much
> >>> better to start an empty project by default than a (probably heavy)
> >>> recent
> >>> project one does not want to continue with.
> >>> Something that might improve the situation in a simple way (though I
> >>> have no problems with the current situation) could be to mark (e.g. grey
> >>> out) projects that were moved (cannot be found at the specified
> >>> location)
> >>> or those could be put to the end of the list or something like that…
> >>> Cheers
> >>> Stefan
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.osgeo.org
> >>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
