[Qgis-developer] rendering tests, what's the latest approach ?
Sandro Santilli
strk at keybit.net
Thu Nov 12 07:37:12 PST 2015
I've found a bug in rendering line-offsetted marker line symbols [1]
and wondering what's the currently recommended way to add a testcase.
[1] http://hub.qgis.org/issues/13811 or
https://github.com/qgis/QGIS/pull/2442
Looking around I see many test files using the QgsRenderChecker
class in tests/src/core but the rationale is not clear to me.
Here's the list:
regression992.cpp
testqgsblendmodes.cpp
testqgscomposerobject.cpp
testqgscomposerutils.cpp
testqgsdiagram.cpp
testqgsgeometry.cpp
testqgsgradients.cpp
testqgsimageoperation.cpp
testqgsinvertedpolygonrenderer.cpp
testqgslabelingenginev2.cpp
testqgslegendrenderer.cpp
testqgslinefillsymbol.cpp
testqgsmaprenderer.cpp
testqgsmaprotation.cpp
testqgspainteffect.cpp
testqgspointpatternfillsymbol.cpp
testqgsrasterfill.cpp
testqgsrasterlayer.cpp
* testqgsrenderers.cpp
testqgsshapeburst.cpp
Then other files use the QgsMultiRenderChecker class instead:
qgscompositionchecker.cpp
testqgsdiagram.cpp
* testqgsstylev2.cpp
* testqgssymbolv2.cpp
What's the difference between the two classes ? Which one should I use ?
Should I put the new case in any existing file ?
(I've tagged the possible candidates with a star)
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
