[Qgis-developer] QGIS Server - use PGSYSCONFDIR in a server with no postgresql installed
kimaidou kimaidou at gmail.com
Thu Nov 19 05:10:28 PST 2015
I just tested, and the file /etc/apache2/mods-enabled/env.conf  with
SetEnv PGSYSCONFDIR "/etc"
is indeed important. Commenting this line would lead to no connection
possible by QGIS Server, even if the env variable is correctly set in
fcgid.conf.
This is the first time I see this behaviour (fcgid.conf not setting
properly an env variable)
Michaël
2015-11-19 14:03 GMT+01:00 kimaidou <kimaidou at gmail.com>:
> Hi Andreas,
> It worked like a charm with your exact configuration.
> I will remove the env.conf file to see if it still works without this
> conf. If so, this would mean the pg_service.conf file situated in
> /etc/postgresql/ could not be read. Probably wrong permissions on the
> folder /etc/postgresql.
> Thanks again for your help
> I add a todo to remember adding this in QGIS Server documentation.
> Regards
> Michaël
> 2015-11-19 13:59 GMT+01:00 Neumann, Andreas <a.neumann at carto.net>:
>> Hi,
>> Here are the properties of my pg_service.conf file:
>> -rw-r--r-- 1 root root 809 Aug 13  2014 /etc/pg_service.conf
>> Andreas
>> On 2015-11-19 13:52, kimaidou wrote:
>> Thanks Andreas for your help.
>> I also think fcgid.conf is the "winner", but I will try your
>> configuration ( move pg_service.conf to /etc/ and add the setenv in Apache
>> env.conf ).
>> Could you please give me the result of
>> ls -lh /etc/pg_service.conf
>> command, so that I completely mimic your configuration ?
>> Cheers,
>> Michaël
>> 2015-11-19 13:00 GMT+01:00 Neumann, Andreas <a.neumann at carto.net>:
>>> Hi Michaël,
>>> This works for me.
>>> My pg_service.conf file is at /etc/pg_service.conf
>>> And in the Apache configuration it is specified in two files:
>>> /etc/apache2/mods-enabled/env.conf :
>>> and in
>>> /etc/apache2/mods-enabled/fcgid.conf
>>> FcgidInitialEnv PGSYSCONFDIR "/etc"
>>> I am not sure which one is really used or has precedence - I suspect it
>>> is the fcgid.conf file.
>>> Hope you get this working,
>>> Andreas
>>> On 2015-11-19 12:17, kimaidou wrote:
>>> Hi all
>>> I have installed QGIS Server in one server (called "map") and PostGreSQL
>>> on another (called "pg" ), both on Ubuntu Server 14.04
>>> I would like to access to database only with PostGreSQL services, so in
>>> the map server, I did the following steps:
>>> * Create a folder /etc/postgresql
>>> * Create a file /etc/postgresql/pg_service.conf  with some credentials
>>> * Install postgresql-client to be able to use psql
>>> * Add a environment variable PGSYSCONFDIR  and export it (plus add it in
>>> /etc/environment ). Variable : PGSYSCONFDIR=/etc/postgresq'l
>>> * Test via psql "service=myservice"  -> I can connect to the database
>>> and get data
>>> When I ask QGIS Server for the GetCapabilities, the layers configured
>>> with this service cannot be added. I get the error : "Service myservice not
>>> found"
>>> So I added the following line in the fcgid.conf file to explicitely tell
>>> Apache (and QGIS Server) to use this value.
>>> FcgidInitialEnv PGSYSCONFDIR "/etc/postgresql"
>>> But nothing works. I even tried to chmod and chown the service file and
>>> folder to let Apache user www-data to read it. I also tried with a quick
>>> and dirty chmod 777 , with no luck.
>>> Has anyone some experience in setting up a Server with no postgresql
>>> installed locally, and use the pg_service.conf file with QGIS Server ?
>>> Thanks a lot for any clue
>>> Michaël
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151119/fe8e6163/attachment-0001.html>
