[Qgis-developer] QGIS Server - use PGSYSCONFDIR in a server with no postgresql installed
Neumann, Andreas
a.neumann at carto.net
Thu Nov 19 05:15:59 PST 2015
yes - Apache confs are sometimes a mystery ...
Thanks for checking.
Andreas
On 2015-11-19 14:10, kimaidou wrote:
> I just tested, and the file /etc/apache2/mods-enabled/env.conf with
> SetEnv PGSYSCONFDIR "/etc"
> is indeed important. Commenting this line would lead to no connection possible by QGIS Server, even if the env variable is correctly set in fcgid.conf.
> This is the first time I see this behaviour (fcgid.conf not setting properly an env variable)
> Michaël
> 2015-11-19 14:03 GMT+01:00 kimaidou <kimaidou at gmail.com>:
> Hi Andreas,
> It worked like a charm with your exact configuration.
> I will remove the env.conf file to see if it still works without this conf. If so, this would mean the pg_service.conf file situated in /etc/postgresql/ could not be read. Probably wrong permissions on the folder /etc/postgresql.
> Thanks again for your help
> I add a todo to remember adding this in QGIS Server documentation.
> Regards
> Michaël
> 2015-11-19 13:59 GMT+01:00 Neumann, Andreas <a.neumann at carto.net>:
> Hi,
> Here are the properties of my pg_service.conf file:
> -rw-r--r-- 1 root root 809 Aug 13 2014 /etc/pg_service.conf
> Andreas
> On 2015-11-19 13:52, kimaidou wrote:
> Thanks Andreas for your help.
> I also think fcgid.conf is the "winner", but I will try your configuration ( move pg_service.conf to /etc/ and add the setenv in Apache env.conf ).
> Could you please give me the result of
> ls -lh /etc/pg_service.conf
> command, so that I completely mimic your configuration ?
> Cheers,
> Michaël
> 2015-11-19 13:00 GMT+01:00 Neumann, Andreas <a.neumann at carto.net>:
> Hi Michaël,
> This works for me.
> My pg_service.conf file is at /etc/pg_service.conf
> And in the Apache configuration it is specified in two files:
> /etc/apache2/mods-enabled/env.conf :
> and in
> /etc/apache2/mods-enabled/fcgid.conf
> FcgidInitialEnv PGSYSCONFDIR "/etc"
> I am not sure which one is really used or has precedence - I suspect it is the fcgid.conf file.
> Hope you get this working,
> Andreas
> On 2015-11-19 12:17, kimaidou wrote:
> Hi all
> I have installed QGIS Server in one server (called "map") and PostGreSQL on another (called "pg" ), both on Ubuntu Server 14.04 I would like to access to database only with PostGreSQL services, so in the map server, I did the following steps:
> * Create a folder /etc/postgresql
> * Create a file /etc/postgresql/pg_service.conf with some credentials
> * Install postgresql-client to be able to use psql
> * Add a environment variable PGSYSCONFDIR and export it (plus add it in /etc/environment ). Variable : PGSYSCONFDIR=/etc/postgresq'l
> * Test via psql "service=myservice" -> I can connect to the database and get data
> When I ask QGIS Server for the GetCapabilities, the layers configured with this service cannot be added. I get the error : "Service myservice not found"
> So I added the following line in the fcgid.conf file to explicitely tell Apache (and QGIS Server) to use this value.
> FcgidInitialEnv PGSYSCONFDIR "/etc/postgresql"
> But nothing works. I even tried to chmod and chown the service file and folder to let Apache user www-data to read it. I also tried with a quick and dirty chmod 777 , with no luck.
> Has anyone some experience in setting up a Server with no postgresql installed locally, and use the pg_service.conf file with QGIS Server ?
> Thanks a lot for any clue
> Michaël
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151119/8d002fc4/attachment.html>
