[Qgis-developer] Inconsistencies between API documentation and code for groups?
Nyall Dawson nyall.dawson at gmail.com
Sat Nov 21 17:22:20 PST 2015
On 22 Nov 2015 7:09 AM, "Thomas Gratier" <osgeo.mailinglist at gmail.com>
wrote:
> Hi,
> If I go to http://qgis.org/api/2.12/classQgsBlendModeComboBox.html
> I see that the class has been classified in
http://qgis.org/api/2.12/group__gui.html
> If I go to http://qgis.org/api/2.12/classQgsMapLayerComboBox.html, the
class does not have any group whereas I would expect this class to be in
the same gui group.
> Why? Both are in the same src/gui directory and in Python QGIS API, doing
the following
The difference is that QgsBlendModeComboBox has the documentation group
set, but not QgsMapLayerComboBox. See:
https://github.com/qgis/QGIS/blob/master/src/gui/qgsblendmodecombobox.h#L25
Vs
QGIS/blob/master/src/gui/qgsmaplayercombobox.h#L26
This should be fixed in QgsMapLayerComboBox.h . I suspect there's lots of
missing groups... Perhaps I should also add this to the documentation unit
test to prevent it in future.
Nyall
> print [c for c in dir(qgis.gui) if 'QgsMapLayerComboBox' in c] # return
the QgsMapLayerComboBox class but it's Python not C++...
> Any idea if it's normal? How can I help to improve this part if it's not
normal?
> FYI, I didn't find an obvious keyword in *.h and *.c files for both
classes explaining why one is included in the doc and the other not. I also
looked at the doxy file template (
https://github.com/qgis/QGIS/blob/master/cmake_templates/Doxyfile.in
without success.
> Cheers and regards
> Thomas Gratier
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151122/617b3cfb/attachment.html>
