[Qgis-developer] Quick fixes and error communication for ftools
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Nov 24 02:29:05 PST 2015
On 24.11.2015 11:13, Matthias Kuhn wrote:
> Hi Marco
> On 11/24/2015 11:01 AM, Marco Hugentobler wrote:
>> Hi Alessandro, Matthias
>> >Is there no requirement for multi types?
>> Afaik, the problem for f-tools are not the multi types, but only the
>> geometry collections (containing geometries with different shape
>> type). In my experience, if geos returns a geometry collection, it
>> usually contains one 'expected' geometry and the others are slivers
>> (@strk, please correct me if wrong).
> I was mostly thinking about collections that contain a multitype with
> several parts which are not considered slivers. This seems to be a
> very valid scenario.
It is, but it was also not handled by f-tools <= 2.8.
>> >Based on what indicator should be chosen what to extract? Try
>> polygons first, if there are none try lines, if there are none take
>> points?
>> One possibility would be to pass the expected shapetype (Point / Line
>> / Polygon) to the function and take the best candidate (e.g. longest
>> line, largest polygon area).
> Before the geometry changes, the algorithms were able to provide the
> results without this additional information. How was that done?
Not sure. Maybe the logic in the geos -> QgsGeometry conversion handled
the collections differently.
Regards,
Marco
>> >How much effort (in time) do you think is required to implement this
>> fix?
>> Difficult to estimate. It seems straightforward to implement the
>> extraction function. Then it needs to be called by the f-tools
>> internally and be tested with a few examples. If unit tests are
>> required (as mentioned by Alessandro), this seems to be the most time
>> consuming task to me.
> Unit Tests for processing are on my todo list anyway (I think as a psc
> member you should have voted for that ;) )
> Matthias
>> Regards,
>> Marco
>> On 24.11.2015 10:42, Matthias Kuhn wrote:
>>> Hi Marco
>>> Good to have your feedback, you probably know the problem best.
>>> On 11/24/2015 09:28 AM, Marco Hugentobler wrote:
>>>> Hi
>>>> >ad issue 1: update fTools to warn users when some features cause
>>>> problems
>>>> >ad issue 2: quick fix fTools to convert geometry collections to
>>>> single geometry types
>>>> A function that takes a geometry type and extracts the longest line
>>>> / the largest polygon / the first point from the geometry
>>>> collection should be straightforward to do.
>>> points?
>>>> >These fixes/updates would be made available as fTools updates via
>>>> the plugin installer asap
>>>> If the fix does not take too long, we probably don't need a warning
>>>> at all.
>>> fix?
>>> Regards,
>>> Matthias
>>>> Regards,
>>>> Marco
>>>> On 23.11.2015 21:35, Anita Graser wrote:
>>>>> Hi,
>>>>> If you are following the psc list, you've probably seen the thread
>>>>> discussing current shortcomings of ftools
>>>>> (http://lists.osgeo.org/pipermail/qgis-psc/2015-November/003623.html)
>>>>> In short, the key issues are:
>>>>> 1. When ftools encounter issues with certain features, warning
>>>>> messages get written to the log but this is largely hidden from
>>>>> users since they would actively have to actively monitor the log.
>>>>> The problematic features are then missing from the results but
>>>>> this is not always obvious.
>>>>> 2. The above issue is more common now (since 2.10) since
>>>>> underlying libraries more often (and correctly so) produce
>>>>> geometry collections as outputs. These geometry collections are
>>>>> not handled well by the current ftools code which is much older.
>>>>> To address these issues, the following suggestions have been made
>>>>> so far:
>>>>> problems
>>>>> For the warnings, there's already a first PR draft
>>>>> https://github.com/qgis/QGIS/pull/2432 which needs to be fleshed out.
>>>>> the plugin installer asap.
>>>>> If you have ideas how to handle this efficiently or have already
>>>>> implemented code that addresses similar issues, let us know.
>>>>> It would be good to have a quick discussion in order to be able to
>>>>> provide improvements fast.
>>>>> Best wishes,
>>>>> Anita
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> List info:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Dr. Marco Hugentobler
>>>> Sourcepole - Linux & Open Source Solutions
>>>> Weberstrasse 5, CH-8004 Zürich, Switzerland
>>>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>>>> Technical Advisor QGIS Project Steering Committee
>>> Matthias Kuhn
>>> OPENGIS.ch -https://www.opengis.ch
>>> Spatial • (Q)GIS • PostGIS • Open Source
> Matthias Kuhn
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151124/b0e04777/attachment.html>
