[Qgis-developer] [QA] CSV Test Flaky
Chris Crook
ccrook at linz.govt.nz
Mon Nov 30 09:30:28 PST 2015
Hi All
Thanks for alert to this message Matthias.. you recall correctly that I am author of these tests.
There is one test which I might have expected to be flaky, which is the test for the file watcher (test 29) - and in retrospect I'm not sure of the value of that feature in any case. In order to make that test work it needs to sleep for a bit and to call QCoreApplication.instance().processEvents(). However from the log file it appears to have successfully passed that test.
After that the tests are all very routine I would have thought - the last test for which there is output, which is test31, is filtering using a spatial index. On the face of it this sounds very straightforward code to me, and not likely to result in a timeout. OTOH this code was built before multithreaded rendering so there is a possibility of some sort of thread insecurity I suppose ... if multithreading in used in the test at all.
In summary I don't have any immediate thoughts as to why it could be ... thoughts anyone?
Cheers
Chris
________________________________________
Sent: 01 December 2015 03:47
To: qgis-developer; Chris Crook
Subject: [QA] CSV Test Flaky
The PyQgsDelimitedTextProvider is flaky for as long as I remember.
It runs into a timeout every once in a while (e.g. here https://travis-ci.org/qgis/QGIS/jobs/93937729#L1285 http://tinyurl.com/pcepj9t)
I guess it runs into a deadlock given that normally it finishes in ~12s and a timeout requires 600s to trigger.
Does anybody have a guess what could be the source of the problem?
Does somebody have a suspicion what could be going on? If yes, please try to find a way to add debug output to verify your guesses.
I will probably disable the test the next time I witness false alarms, I hope somebody jumps in before :)
Matthias
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
