[Qgis-developer] Inverted polygon renderer and shapeburst fill in qgis server tiles
Régis Haubourg regis.haubourg at eau-adour-garonne.fr
Thu Oct 1 02:32:24 PDT 2015
Hugo Mercier wrote
> The solution proposed by Nyall (adding the possibility to have an
> infinite distance if I understood correctly) is better I think.
Hi Hugo,
you're right. If someone has sufficient math skills to avoid a dirty
workaround, I'd be pleased to have him work on it ;-).
Cheers
Régis
View this message in context: http://osgeo-org.1560.x6.nabble.com/Inverted-polygon-renderer-and-shapeburst-fill-in-qgis-server-tiles-tp5224645p5227264.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
