[Qgis-developer] SSL error on QGIS startup
Andreas Neumann
a.neumann at carto.net
Thu Oct 1 23:18:45 PDT 2015
To add some more information: this is on Ubuntu 15.04 64bit.
I also tried starting QGIS without plugins, because I thought that maybe
a Python Plugin may want to load something from the web, but the error
message still appears.
Thanks,
Andreas
On 02.10.2015 08:07, Andreas Neumann wrote:
> Hi,
> Since the integration of the new authentication system from Larry I am
> now getting an SSL error on Startup. See
> http://www.carto.net/neumann/temp/qgis_startup_ssl_error.png
> I have no idea what it means and what I can do in order to get rid of
> this error message.
> Does it mean that the connection to https://www.google.com/jsapi is
> not secure? Is QGIS now contacting a Google server at each startup?
> Thank you for any hint about this error message.
> Andreas
> Qgis-developer mailing list
