[Qgis-developer] New GRASS plugin: a test drive
Paolo Cavallini
cavallini at faunalia.it
Mon Oct 5 06:41:14 PDT 2015
Il 05/10/2015 14:58, Paolo Cavallini ha scritto:
> I think the context menu is fine, and adding it should not be an issue
> now (I could say not being able to readily use my data is a bug, and
> your suggestion fixes it).
the procedure described in the wiki works smoothly from the embedded
GRASS shell, but I guess this is intimidating for many users.
> yes - I tried, but the newly added polygon etc is not displayed once
> digitized. Oh, now I see: the custom grass symbology prevents me from
> seeing it. Once moved to single symbol, it is displayed.
I confirm an issue: I load a layer, activate editing, the layer is no
longer visible. When editing is deactivated, the layer remains invisible.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
