[Qgis-developer] New GRASS plugin: a test drive
Paolo Cavallini cavallini at faunalia.it
Mon Oct 5 09:17:22 PDT 2015
Il 05/10/2015 17:18, Radim Blazek ha scritto:
> OK, but first I have to fix other bugs.
sure - should I open a ticket then?
> There is v.build.all in modules.
yes, but the user has no hint about its necessity; further steps:
db.connect -d
v.db.reconnect.all -cd
are not available among modules (BTW, maybe these options could be added
to existing modules?).
> There was a bug which I introduced on Friday, it was fixed in b09877b.
> The style must be set (automatically) to GRASS Edit to get topological
> symbology.
OK, thanks, I'll check.
> Documentation is not yet upgraded, but you can write it....
I'm not much of a digitizer myself, better leave it to someone more
expert. If no one is available, I can try.
Thanks a lot.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
