[Qgis-developer] Error during saving shapefile
Matteo Ghetta matteo.ghetta at gmail.com
Wed Oct 7 07:03:05 PDT 2015
yes..
browse and manually added the name of the file...
2015-10-07 14:33 GMT+02:00 DelazJ <delazj at gmail.com>:
> Hi,
> Isn't there somehing wrong with the name of your file (/ww.shp)? Did you
> browse and select a folder + name for your file?
> 2015-10-07 13:54 GMT+02:00 Matteo Ghetta <matteo.ghetta at gmail.com>:
>> Hi all,
>> a problem with OSX and QGIS 2.10.
>> I've loaded a shapefile and just tried to save it as a new shapefile,
>> that's the error:
>> Esportazione nel file vettoriale fallita.
>> Errore: non riesco a creare il layer (errore OGR:Failed to open Shapefile
>> `/ww.shp'.
>> I've not touched the shapefile (attribute table, CRS.. all the same).
>> Coding is default (System).
>> Something wrong with some option?
>> Thanks
>> Matteo
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151007/184b26de/attachment.html>
