[Qgis-developer] Error during saving shapefile
Matthias Kuhn matthias at opengis.ch
Wed Oct 7 07:33:32 PDT 2015
Hi Matteo,
>From the path it looks like you are saving directly to the root folder
`/ww.shp` which is likely to be write protected for regular users. Can
you manually enter your home folder or another path `/home/[matteo]/ww.shp`?
Matthias
On 10/07/2015 04:03 PM, Matteo Ghetta wrote:
> yes..
> browse and manually added the name of the file...
> 2015-10-07 14:33 GMT+02:00 DelazJ <delazj at gmail.com
> <mailto:delazj at gmail.com>>:
>     Hi,
>     Isn't there somehing wrong with the name of your file (/ww.shp)?
>     Did you browse and select a folder + name for your file?
>     2015-10-07 13:54 GMT+02:00 Matteo Ghetta <matteo.ghetta at gmail.com
>     <mailto:matteo.ghetta at gmail.com>>:
>         Hi all,
>         a problem with OSX and QGIS 2.10.
>         I've loaded a shapefile and just tried to save it as a new
>         shapefile, that's the error:
>         Esportazione nel file vettoriale fallita.
>         Errore: non riesco a creare il layer (errore OGR:Failed to
>         open Shapefile `/ww.shp'.
>         I've not touched the shapefile (attribute table, CRS.. all the
>         same).
>         Coding is default (System).
>         Something wrong with some option?
>         Thanks
>         Matteo
>         _______________________________________________
>         Qgis-developer mailing list
>         Qgis-developer at lists.osgeo.org
>         <mailto:Qgis-developer at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151007/b8b87c44/attachment.html>
