[Qgis-developer] Processing: return table from PostGIS query
kimaidou
kimaidou at gmail.com
Thu Oct 8 03:31:18 PDT 2015
Hi again
I have seen there is a bug in the current versions of the script. I need to
adapt them ( Processing has changed a bit since I write them)
If you cannot wait, juste replace the following line in the script
from processing.core.VectorWriter import VectorWriter
by
from processing.tools.vector import VectorWriter
It must do the job
2015-10-08 11:46 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi Spencer
> I have created a script to do so. You must been able to get it via the
> Processing Toolbox : Scripts / Tools / Get scripts from online collection
> The script is called "Create vector layer from PostGIS table"
> You also have one calle "Create vector layer from SQL query" which allows
> to create a vector layer from a query
> Cheers
> Michaël
> 2015-10-08 3:54 GMT+02:00 Spencer Gardner <spencergardner at gmail.com>:
>> I'm writing a processing routine for which I want to send a query,
>> receive a table from PostGIS in return, and then do something with the
>> results. Is there an easy way to do this in Processing?
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151008/8d132e65/attachment.html>
