[Qgis-developer] Default fill/outline color for svg symbols
m roy
royroge at outlook.com
Sat Oct 10 05:56:51 PDT 2015
Il 10/10/2015 13.36, Mathieu Pellerin ha scritto:
Argh, forgot one other related question:
At the moment, changing the symbol resets the full and outline color
to match the default fill/outline set in the SVG symbol. I'd like to
change this behaviour so that whatever user-set fill/outline color is
kept when changing the source svg symbol. Any objections?
Not so sure about that, what if you put on a white tie,
then you see a grey one and when you switch the white
one with the gray, the gray become white?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151010/4de98528/attachment.html>
