[Qgis-developer] Crash Dump 2.11 with user defined expressions
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Mon Oct 12 08:19:14 PDT 2015
Might be a regression:
https://hub.qgis.org/issues/13059
Cheers,
Saber
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of João Gaspar
Sent: 12 October 2015 16:11
To: Alexandre Neto
Cc: qgis-dev
Subject: Re: [Qgis-developer] Crash Dump 2.11 with user defined expressions
Alexandre,
i confirm this behavior.
In Windows 7 64-bits:
OSGeo4W Installer (64-bits) QGIS Master version ac3f390
After i put your functions in the folder of expressions .qgis2\python\expressions when i start the QGIS he starts with minidump crash and don't open.
Regards
João
2015-10-12 15:58 GMT+01:00 Alexandre Neto <senhor.neto at gmail.com>:
Hello all,
I'm having Crash Dumps in current master, on windows 7 64 bits. After a few tests and some .qgis2 cleaning I realized it has something to do with expression functions created by user.
The attached file makes qgis crash dump, if you try to open the expressions dialog.
It works in QGIS 2.8.3 tho.
Did not test on Linux.
Best regards,
Alexandre Neto
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell pro
ducts, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151012/4ce7a100/attachment.html>
