[Qgis-developer] Crash Dump 2.11 with user defined expressions
    Alexandre Neto
    senhor.neto at gmail.com
    Mon Oct 12 08:46:55 PDT 2015
I have opened a new ticket:
https://hub.qgis.org/issues/13579
Em seg, 12 de out de 2015 às 16:29, Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> escreveu:
> Might be a regression:
> https://hub.qgis.org/issues/13059
> Cheers,
> Saber
> *From:* Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] *On
> Behalf Of *João Gaspar
> *Sent:* 12 October 2015 16:11
> *To:* Alexandre Neto
> *Cc:* qgis-dev
> *Subject:* Re: [Qgis-developer] Crash Dump 2.11 with user defined
> expressions
> Alexandre,
> i confirm this behavior.
> In Windows 7 64-bits:
> OSGeo4W Installer (64-bits) QGIS Master version ac3f390
> After i put your functions in the folder of expressions
> .qgis2\python\expressions when i start the QGIS he starts with minidump
> crash and don't open.
> Regards
> João
> 2015-10-12 15:58 GMT+01:00 Alexandre Neto <senhor.neto at gmail.com>:
> Hello all,
> I'm having Crash Dumps in current master, on windows 7 64 bits. After a
> few tests and some .qgis2 cleaning I realized it has something to do with
> expression functions created by user.
> The attached file makes qgis crash dump, if you try to open the
> expressions dialog.
> It works in QGIS 2.8.3 tho.
> Did not test on Linux.
> Best regards,
> Alexandre Neto
> Qgis-developer mailing list
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately by e-mail if you have received this e-mail by mistake and
> delete this e-mail from your system. If you are not the intended recipient
> you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly
> prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to carry
> out such checks as you feel appropriate.
> If this email contains a quote or offer to sell products, carry out work
> or perform services then our standard terms and conditions
> <http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf>
> shall apply unless explicitly stated otherwise.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20151012/322ab111/attachment.html>
