[Qgis-developer] Problems with QgsPluginLayerRegistry
Sören Gebbert
soerengebbert at googlemail.com
Tue Oct 13 00:08:49 PDT 2015
no, i did not solved it.
However, it does not effected my plugin[1].
The main problem that i had was with QgsPluginLayer. All created
layers needed to be managed in addition to the QgsMapLayerRegistry,
since the Python garbage collector seems to delete layers, even if
they are referenced by the registry.
Best regards
Soeren
[1] https://bitbucket.org/huhabla/grass-data-explorer
2015-10-13 7:58 GMT+02:00 Ducarouge <benoit.ducarouge at province-sud.nc>:
> Hi,
> I have the same problem,
> did you find a solution ??
> thanks
> Ben
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-QgsPluginLayerRegistry-tp5222383p5229594.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
