[Qgis-developer] New GRASS plugin: a test drive
m roy royroge at outlook.com
Thu Oct 15 01:49:49 PDT 2015
Il 14/10/2015 19.01, Radim Blazek ha scritto:
> On Thu, Oct 8, 2015 at 1:07 PM, m roy <royroge at outlook.com> wrote:
>> Vector digitizing: QGIS crash when deleting a line and the layer
>> is not longer loadable in QGIS because of broken topology,
> Fixed, it was the different off_t size in GRASS and QGIS on Windows.
> It should work in the next nightly build 2.11.0-90.
> Radim
After some quick vector digitizing tests: awesome tool
for QGIS !!
the only (minor) issue i found is that area boundary color does not
match the simbology settings (e.g. green boundary also if it's not
shared by two areas)
thanks, Roy.
