[Qgis-developer] New GRASS plugin: a test drive
    Radim Blazek
    radim.blazek at gmail.com
    Thu Oct 15 04:25:32 PDT 2015
On Thu, Oct 15, 2015 at 10:49 AM, m roy <royroge at outlook.com> wrote:
>>> Vector digitizing: QGIS crash when deleting a line and the layer
>>> is not longer loadable in QGIS because of broken topology,
>> Fixed, it was the different off_t size in GRASS and QGIS on Windows.
>> It should work in the next nightly build 2.11.0-90.
> After some quick vector digitizing tests: awesome tool
> for QGIS !!
> the only (minor) issue i found is that area boundary color does not
> match the simbology settings (e.g. green boundary also if it's not
> shared by two areas)
Green means that both sides are topologically correct. If there is no
area outside a ring, it is correct. Try to attach a dangling boundary
to the ring and it should become orange.
Maybe the name in symbology is not precise.
Radim
