[Qgis-developer] grass plugin: r.contour failing
Paolo Cavallini
cavallini at faunalia.it
Fri Oct 16 07:21:02 PDT 2015
Il 16/10/2015 13:46, Radim Blazek ha scritto:
>> r.contour input=dtm_loc at PERMANENT step=100 minlevel=0 maxlevel=5000000
>> output=cont2
>> Lettura dei dati in corso ...
>> Modulo crashato o interrotto
> It happens only when run from QGIS GUI and works if the same command
> is run from GRASS shell?
It happens both from the QGIS GUI and from the QGIS embedded shell.
BTW: it is apparently not possible to paste commands in the shell, a
major annoyance - should I open a ticket?
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
