[Qgis-developer] grass plugin: r.contour failing
Paolo Cavallini
cavallini at faunalia.it
Fri Oct 16 08:30:18 PDT 2015
Il 16/10/2015 16:52, Radim Blazek ha scritto:
> So it seem to be a problem in r.contour, thus question to grass list.
ok, will do. I suspected an issue from QGIS side because of
QgsGrassRasterProvider::statusChanged( QString ) in
/tmp/buildd/qgis-2.11.0+git20151013+e193c7c+99unstable/src/core/raster/qgsrasterlayer.cpp:842
> Do you mean X Windows selection + paste by middle button? That works
> for me. If it does not work for you, please create a new issue and
> possibly try to find more details when it does not work (copy from any
> application or just from module's output, distribution, KDE/Gnome...)
> If you mean Ctrl+C + Ctrl+V, it is not implemented. You can create
> feature request issue.
that was it. done:
http://hub.qgis.org/issues/13625
thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
