[Qgis-developer] New GRASS plugin: a test drive
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Fri Oct 16 14:47:36 PDT 2015
Hi Radim,
Another issue:
The temporal maps are not listed in the input widgets. I assume that a "translation" for GRASS parser options (https://grass.osgeo.org/programming7/parser__standard__options_8c.html) to the QGIS GUI is missing for the temporal modules:
G_OPT_STDS_INPUT
G_OPT_STDS_INPUTS
G_OPT_STDS_OUTPUT ...
Not essential, but makes them easier to use...
Kind regards
Stefan
-----Original Message-----
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Radim Blazek
Sent: 6. oktober 2015 13:42
To: Paolo Cavallini <cavallini at faunalia.it>
Cc: qgis-developer <qgis-developer at lists.osgeo.org>
Subject: Re: [Qgis-developer] New GRASS plugin: a test drive
On Tue, Oct 6, 2015 at 8:12 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
>>> yes - I tried, but the newly added polygon etc is not displayed once
>>> digitized. Oh, now I see: the custom grass symbology prevents me
>>> from seeing it. Once moved to single symbol, it is displayed.
>>> I confirm an issue: I load a layer, activate editing, the layer is
>>> no longer visible. When editing is deactivated, the layer remains invisible.
>> There was a bug which I introduced on Friday, it was fixed in b09877b.
>> The style must be set (automatically) to GRASS Edit to get
>> topological symbology.
> I still see the issue on current Debian sid package, just upgraded.
Which revision? Please use current master if possible.
Please start with points and lines. When you digitize a point or line, nothing is displayed in canvas? Do you see the elements if you switch style to default? Do you see the features in attribute table? Are the elements written to the map when you close editing?
Note that QGIS can only display features of one type in a layer, if you add point layer and digitize a line, it will no show in point layer after editing is closed, a new layer with lines must be added to canvas.
Radim
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-developer
